converting Pro e 3D model to Autocad
  • Thread starter Thread starter vivekt_123
  • Start date Start date
V
vivekt_123
Guest
Hi all,
Is it possible to convert a pro e 3D model to Autocad 3D. I need it desperately. Please give me a solution.
just check out with neutral file will open in autocad
I remember that we have tried with IGES
may be u require mechanical desktop or Inventor in between proe and autocad
Ya its possible I did itlong back.
Save pro-e model as ACIS (*.sat) and you can import it in autocad by using import command.
I think this will help.
Edited by: sureshdesigns
Thank you for your reply.
I think it is not possible in Pro e 2001
From my experience, an ACIS (*.sat) is the best option for importing into AutoCAD. However, not all versions of AutoCAD will except all versions of ACIS.
For example, a client needed to import a part file into AutoCAD 2002. Pro-E could export several versions of ACIS, but AutoCAD 2002 would only import ACIS version 4.0 and earlier. We determined this through testing.
Edited by: c_thompson_68
