CONVERTING DWG to DGN
KLV
I have a road project with plan and pro sheets in model/paper space in Autocad R14 and need to convert them to Microstation J. Numerous attempts and just can't get it right. I am told it can be done but nobody I deal with knows how. Any help would be great. TIA, KLV
This should be a simple task.
Basically go into MicroStation J, at the bottom change the filter from DGN to DWG, and click to the DWG and open.
If you wish to BIND the files in MicroStation, then you need to open a "BLANK" file in MicroStation. Go to file> import> DWG. Point to the file and click ok. Before clicking OK again go through the options as to how to handle the XREFs.
You may need to "EXPLODE" your elements in AutoCAD *** BEFORE *** the translation. BURST would be a better command to use in AutoCAD. "Burst" is a form of EXPLODE ... it just has more control over the elements than normal EXPLODE.
Hope that helps.
R. [roll2]
Thanks rKeyTek. I "burst" the ref file then bound it in ACAD before opening in MS. Then used sheet file in MS and it worked beautifully. Thanks again. KLV
