racookpe1978
Nuclear
I have a large portable US built oil filter system that (now) can only run properly on Europe's 50 Hz system by requiring a extra 60 Hz generator and fuel tank.
Obviously, renting the generator is too expensive now days, hurts sales and increases costs and setup time.
If I run at 1450 rpm (nominal 1500) instead of 1800 rpm, my flow is too small. (250 HP motor, 440-480 volt @ 60 Hz, pump is a ITT 10x12x14 3405 type with a max impeller, flow spec is 4200 gpm minimum.)
if I change pumps (and use the same motor at but at the European 380-420 volts and 50Hz ) to the larger 10x12x17 casing, It appears I can regain the flow and keep in the same 3405/3410 "family" so my baseplate still fits.
Filter, suction and discharge piping would stay the same, so I expect the resistance to be the same.
The new casing moves the pump suction and discharge lower by 1 inch - but physically I can shim up motor and pump casing back to old height. Left right distance can be compensated for.
How do I specify the coupler to ensure a match (old motor to new pump)?
Any other problems anybody can forsee?
