Hello, I am trying to run a Riks analysis on a straight pipeline with an initial small imperfection. I define the nodes, apply pressure and weight loads and then I start the Riks analysis. I have tried many many times but the model doesn't seem to converge. Not even when I apply the pressure or weight loads. I get the note: "***NOTE: THE SOLUTION APPEARS TO BE DIVERGING. CONVERGENCE IS JUDGED UNLIKELY" and it stops after a few attempts. I also tried a *Dynamic step but that didn't work either. I can't understand what I am doing wrong. I have tried with a very small step but the error persists.
The BC are:
left/right node: 1,2,3,4,6
all pipe nodes: 2,4,6
There are also PSI34 elements along the pipe's length to model soil interaction.
And the Riks step is:
*STEP, NAME=BUCKLING, NLGEOM=YES, INC=30
*STATIC,RIKS
1e-5, 1., 1e-15, 1., ,
*Temperature
ALLNODES, 300
*OUTPUT, FIELD, FREQUENCY=1
*NODE OUTPUT
U,RF
*END STEP
Thank you in advance!
The BC are:
*STATIC,RIKS
*Temperature
ALLNODES, 300
*NODE OUTPUT
U,RF
*END STEP
