nilaypathak
Hi All,
We do have 6" submersible Pump in house. It is 80 L/s at 12mt head.
We would like to use this pump for filter Wet testing which require around 20L/S at 4mt residue head. Delivery head is 6mt.
Can this pump be use if two parallel pipe system with gate vale? One goes back to tank ad other line use for intended purpose (20 l/s).
With all hose & fittings, how thrust effect can be handle on tee fitting with gate valve where flow should be control.
Thanks for your valuable time in advance.
