electrageek
I have an application that currently uses a 480Vac, 400A shunt trip circuit breaker (CB). The load is a 225KVA SCT (saturable current transformer)resistor heating system for annealing metal parts. The problem is that after each cycle they trip the 400A CB to shut off the heating power. After a number of trips the breaker malfunctions and needs to be rebuilt mechanically. I want to replace the 400A CB with a 400A rated vacuum contactor (Siemens part 300HP @ 480Vac). Besides the 400A CB inside the heating unit itself there is also a 400A CB back in the Electric Room that supplies the 400A CB in the unit. I would be keeping that breaker and it is lockable where as the local breaker is not. What do I need to be concerned about if I replace the local CB with the contactor.
