Dear All,
I am trying to define a "SurfaceToSurfaceContact" interaction between two surfaces which have a common edge. Initially, these two surfaces are separated (taking a "V" shape). I apply Boundary Conditions to close the surfaces onto each other. In the next step I want to apply Contact conditions such that the surfaces bond to each other. I would like to achieve this by using the "SurfaceToSurfaceContact" interactions. I define one surface as the master and the other as the slave. Since the two surfaces have a common edge, when I run the simulation I get the following error:
"Error in job ClosingAWedge0: THE SLAVE SURFACE ASSEMBLY__PICKEDSURF10 HAS 220 NODES IN COMMON WITH ITS MASTER SURFACE ASSEMBLY__PICKEDSURF9."
Is there any way around this problem? Is it possible to define the region of a surface without the common edge? I know this is possible for defining sets by using the "xEdges" argument. Is there anything like that while defining surface regions?
Any comments are highly appreciated.
Thanks,
Srikanth
Thanks,
Srikanth
