Construction of Cast In-Situ Piles:
nurhforward
Geotechnical
NG
My company is working on 9-span reinforeced/precast concrete brigde. The construction is to take place on swampy, marshy, silty-clay soil; a 20-30m depth cast
in-situ piles with shell is to be installed until it meet a refusal. The detailed engineering design of the piles has not be concluded by the project consultants, but its estimated that each pile is to carry a design load of 40tons.
As a pile engineer on site, I do not have much experience on construction of pile foundations/footings. Right now, I am required to start planning for the construction of the piles, their installations,pile caps, load testings and other post-constructions activities on piles before the piers can be erected.
I need a guide on how to manage the this aspect of the project espectially on the following :
1. Planning for the pile installations
2. Dialy site reports/ activities
3. Prescribed Load tests on cast in-situ
4. Technical report and presentations
5. General assessment & details that concerns the engr.
6. Appropriate Design tools (CAD) for engg design.
Thanks.
nurhforward, Gitto International.
Does your company or your local transportation authority have an appropriate structures manual?
Check first, or risk reinventing the wheel.
If not, I suggest you start by adapting some existing guidelines to your project.
Many state DOT's have what you need.
Florida has a lot of material on drilled shafts.
