Gwynn:
My experience has been like Bridgebuster’s, I’ve done a bunch of that unusual engineering work over the years. I actually think it’s fairly interesting engineering because it takes a good amount of experience and engineering judgement, drawn from many different areas of practice, rather than just following today’s convoluted cook books, using one material. Of course, it is probably also a little riskier since you can’t fall back on having followed the cook book to the letter, so I must be o.k. That type of engineering work also requires some trust and confidence in the people you are doing the engineering for, and that they know what they are doing, so as not to put your whatcha-call-it in the ringer for you. You really have to think through the problem, for all the possible things which might influence the outcome, not just follow a three step formula to what you assume must be the perfect solution.
I also think that you will find a number of people on this forum who can talk with you, on a large variety of problems, since they have had similar experiences. I also suspect that many of these people will be some of the older folks who have had a much broader experience over the years. I don’t think you need another forum for your questions, but it is absolutely true on all of these forums, and I’m not pointing specifically at you, that many of the questions are poorly asked with insufficient explanation of the problem or too little info. to really discuss the problem, and then we are left to guess what is wanted or needed. We just can’t see it from here, and we don’t know which way ‘on the left’ is. I actually wonder, at times, if the OP’er understands his own problem, if he can’t ask the question any better than that.
We don’t all have first hand knowledge about everything, but if you can explain the problem in regular engineering language and terms, there are a bunch of smart engineers here who can help you toward a well reasoned solution; or at least in the right direction without making the final decisions for you. Many of these types fo engineering problems don’t have a cut-n-dried solution, or formula to follow, or design guide #67 with worked out problems which you just substitute your numbers into; so many of today’s engineers don’t know what to do with those problems.
You may be in a fairly small niche, but it is important and essential one. All you have to do is look at many of the structural failures in the news these days, and it is evident that more of this type of construction engineering is needed. And, I think this kind of engineering will become even more important in the future, because too many of today’s design engineers have no idea if what they design can be put together, or how. Computers allow them to do things, at a complexity level, that they just don’t even comprehend. All they know is that if it ain’t too red, it’s probably o.k.
Bring your questions here, they are the most interesting types of engineering questions being asked here these days.
