I've got a problem where the increased thickness of a connection plate increases the overall eccentricity of the joint, thereby causing the failure of the other plate.
The attached should clarify what I'm trying to explain. It's the fixed base moment of the thinner plate which is theoretically increasing and failing.
Is there a rational explanation why the base moment would not be what it seems, ie. 'axial load x e'?
It seems counter-intuitive that an increase in plate thickness would result in over-stress.
