SteelPE
- Mar 9, 2006
- 2,759
I was wondering what the community thought about the proposed change to the AISC Code of Standard Practice Section 3.1.2, which allows the design of the connections to “be designated to be designed by a licensed professional engineer working for the fabricator”.
You can view an article here:
I personally think that connection design should be done during the design of the structure. There have been many times when I had to change beam and column designs to account for the required connections… especially with all the seismic design requirements.
I have also worked with fabricators before and getting reaction information out of engineers that is other than “the connection shall be designed for the maximum end reaction/moment” is next to impossible.
This is just my opinion and I’m sure many of you will disagree.
