katwalatapan
I'm working on an application to connect Carbon Monoxide (CO) alarm in a utility room with the building's fire alarm panel so that the CO alarm could be monitored via an off-site monitoring station. In conventional panels both Kiddie and BRK have CO alarms and relevant relay modules which could connect the CO alarm to the fire alarm panel, however I'm not too sure about this application in addressable fire alarm panels. Is it possible to connect a Kiddie or BRK CO alarm with the relevant relay module to the addressable fire alarm panels? Or would we require a CO alarm and relay module specific to the addressable fire alarm panel manufacturer for compatibility. The objective is to send the alarm/trouble signal from the CO alarm to the off-site monitoring.
Thank you.
Thank you.
