Israelkk , thanks for your help .
About the book , it is a old one, author Celso Maximo del Cosso , edited in 1952 at Madrid Spain .
but this formula is equal to one I got from other old book
Machines from Germany and I found it too here
I had change J [Polar area moment] = Ix + Iy =
(pi d^4 / 64 )* 2 = pi d^4/32
thus the term
pi/(2*j) = pi/2 * (32 /(pi d^4))= 16/d^4
about the term
((r1^2+r2^2)* (r1+r2))
it is the same at all books
I'm new on this topic , and I want to learn.
I'm a 56 years old student since the last 39 years when I begun my technician carrer, of course I got my degree by 1969, but allways I kept learning a bit every day.
In this case I need a conical spring 100 mm free length , to be closed at the wire diameter, the outside big diameter is 70 mm , the inside small diameter 38 mm.
the whole stroke [100 mm] is done in about 10 seconds , and the run to the whole length by the spring own speed .
It guess the load would be about 5 to 7 Kg.
It will be used on a two diameter hole saw to extract the piece of material cuted.
So the compression is done while cuting the 100 mm and the expansion is done when the cut is end through the material tickness.
The piece to extrac is like a washer 76 mm od 34 id the 100 mm is because the material is diplayed in 20 each 5 mm layers.
Hope it make clear.
I had done a calc , I will post it here later , I had to copy and paste.
Thanks again
Pardal
