Hello ladies and gents,
I decided to post this in the structural section because it has more traffic than the RISA forum...
I am having an issue with some results RISA is giving me for a wall panel analysis I am doing. I will be submitting this question directly to RISA as well and will update this post when feedback is provided. In the meantime I wanted to get y'alls opinion on the matter.
I am analyzing an underground sump for a heavy equipment surcharge load. I have modeled a wall panel in RISA (24.5' tall and 53' Long). I applied a lateral earth pressure load and an equipment surcharge load to the ENTIRE wall panel. These loads are applied as surface loads and are out-of-plane loads to the wall. I run the model and get an applied shear and applied moments (in-plane and out-of-plane). I agree with the moment and shear capacity given by RISA.
Here's where things get funky
I recreate the model but instead divide the model into three equal length wall panels (24.5' high and 17.67' Long). I still apply the lateral earth pressure to each wall panel, however I only apply the equipment surcharge load to the center panel to replicate real-world conditions. So, I am applying 1/3 of the surcharge load that was applied in my first model and the same lateral earth pressure. I would expect to see results showing a lower out-of-plane moment but I get the opposite. My out-of-plane moment has gone up by some 30 kip*ft! I cannot reconcile these results with my logic. I have started from scratch and still end up with similar results...
Do you guys have any opinions, or am I missing something? I have attached a pdf showing both scenarios with the results.
