Conductive epoxy approved by MAPTIS
jcole
6
I require an epoxy with the following specs:
1. room temp or relatively low temp cure
2. electrically conductive
3. passes flammability and toxicity ratings on the MAPTIS database
Does anyone know of such a product?
Thanks,
try Sauereisen Cements, Pittsburgh, they have some conductive epoxies
coductivety can be acheived with the diletric addatives . temperature range cure can be modified to suit by hardener. Low toxity but i am not clear on these requirements. Mas Epoxies is great source !
I need a conductive epoxy similar to (but much cheaper)than silver loaded epoxy by circuitworks.
Is there an additive I can use for a standard epoxy?
Something with good electrical properties, a copper, nickel or Al base.
Thanks.
Gary
