We have a device that needs to water emitted in an exhaust stream of a diesel engine. that is about all I can say about it.
So I am basically looking to route the exhaust through a condenser, collect the water and let the remaining exhaust pass through.
There are some issues with this. First if I do it early enough in the pipe (i.e. before any catalytic converters or anything) the water will be quite acidic.
Second, I want to limit the number of components required to do this. So I am thinking of using the condensed water as the media to remove heat also. Basically, collect water in the bottom of something that would look like a sink trap (but not full, otherwise I add significant pressure drop to the exhaust stream), pump that water at say 10 psi through a radiator, and into a spray nozzle that throws the cooled water into the exhaust stream to collect even more water. The pressure supplied by this pump would supply the water to other areas of the device also.
What do you think of this design? Is there something obivously better? Is it a dumb idea?
so my final questions are: how do I size the radiator and where to I get one? how do I size the flow rate for the cold water spray? I realize its about how much heat I want to remove in order to get the water to condense. but I am unsure of how to get at that.
Im a mechanical engineer who hates engines and thermo. mechatronics is my area.
