I doubt that this is because the cement is hot, certainly I have never seen it. I suggest that the cement is hot because it has come straight from production maybe due to a cement shortage on the market where you are working. Is it possible that this has also encouraged the concrete supplier to use some expired cement as well. It can often be seen that expired cement has hard lumps which may not be broken down in the batching plant.
Zambo
