When we design concrete tanks walls, we use vertical construction joints at approximate third points. I try to make the joints coincide with the end of the middle horizontal bar that would lap with the corner bar. This reduces the horizontal shrinkage effects. I have problems isolating the middle horizontal bar for smaller tanks. Where do you place vertical construction joints in concrete tanks?
Where the base slab meets the tank wall, we use either a starter wall to accomodate a PVC waterstop or we roughen the surface and don't uses a starter wall or key when we use a Hydrotite waterstop. In both cases we rely on shear friction to transfer the shear from the wall to the base. However, we use keys in the vertical wall construction joints. How do you detail your vertical wall construction joints? Do you use keys? Do you roughen the joint and rely on shear friction? I think roughening the joint on a vertical surface would be too labor intensive. I'm interested in your input.
