A concrete test requires at least two cylinders being broken, of which the average is used.
During a concrete testing on a project, I got a low strength result from a pair of cylinders on the 7 day break. As it was very low, I just broke one cylinder on the 28 day break and save the last one for the 56 day break.
So I had an one cylinder test result for the 28 day break and it was, as expected, low in strength.
We finally took cores and the core test result was satisfactory.
My question is whether I shall include that one cylinder test in the concrete statistical analysis.
If I include it, it is an one cylinder test. If not, the whole analysis would lose the most obvious change in the construction process.
Any advice will be appreciated.
