Greetings,
I have been assigned the task of designing a single-story office building using reinforced concrete in accordance with ACI 318-14. This building is placed in seismic design category D with site class C. According to ACI and what other buildings are designed and built with, LFRS is a suitable special concrete moment frame. The decking system is a prefabricated hollow core slab that is placed on the frame. I would like to know when I design the frame, is my LFRS the whole frame or just the perimeter beam column? If this is the case, does the beam column detailing look for the non-LFRS? This is my first concrete design. Any expert opinion is appreciated.
Building geometry: 80ftx60ft
Building height: 13 feet
Size of columns according to architectural standards: 20"x20"
Size of beams according to architectural criteria: 20"x20"
Some background information:
J. Wind loads: initial wind speed, using a 3-second gust, 177 km/h (110 mph), exposure C, and
Importance factor of 1.0 determined from ANSI/ASCE 7-16.
D. Seismic design: spectral acceleration based on Ss = 1.12g; S1 = 0.53g, hazard category II, site class D,
Coefficient of importance (ie) = 1.0.
Seismic design category: D
Correction factor, R = 8.
The foundations are designed for an allowable bearing capacity of 72 kPa (1500 psf).
Subgrade modulus 40.7 MPa/m (150 lb/m2). in/in). Ka and kp are considered 0.33 and 3.0
Respectively.
Respectively.
