bridgemaster
Is there a visual test an structural inspector can perform to determine if a concrete spall is caused by either carbonation (CARB) or chloride intrusion (CI)? I am not concerned with structural cracks such as flexure or shear cracks that eventually cause a spall. My understanding is that both CARB and CI spalls occur due to the expansion of corroding steel reinforcement, but the mechanisms are different for how the corrosion is initiated.
Essentially, I would like to know if there is a easy visual method to differentiating a CARB and a CI spall without lab testing of chemicals, etc. Maybe the shape of the spall gives it away? Maybe the reinforcement deteriorates in a unique fashion?
Type of concrete structures that pertain to my inspections: prestressed piles, prestressed slab beams, RC columns, RC beams, RC pile caps.
Thanks in advance for any help!
