I am reviewing some old calculations/design of a 4' thick concrete footing. The design engineer placed their required (As.min) flexural reinforcement (tension/compression) on the top and bottom faces in each direction. This I understand. However, they placed an additional layer of reinforcement in the dead center of the footing, and this is where I'm questioning the logic. Based on the calculations, it appeared that the rebar is used simply as temperature reinforcement, but I know there is sufficient quantities in the top and bottom layers to account for this. Additionally, the location of the rebar is basically useless in my opinion because its situated on the neutral axis. Am I missing something here?
