If you have the compression strength of 4000 psi or greater in your cylinder test breaks.
What are the long-term effects with not having any aggregate fractures (bond failure); cylinders with lateral and Hort. shears and no concrete stink to the rebar (rebar can be washed clean with minimum to no effort)? Need some second opinions.
