bookowski
- Aug 29, 2010
- 983
Question regarding a shift in plan location and/or orientation of a concrete column, "column walk".
In my training I was taught to check the following: confirm that the overlapping area works as a short column (x1 by y1 in attached sketch), and that the resultant overturning forces from the column P x e can be resolved in the slab diaphragm with addition reinf as applicable - this is more or less saying to do a strut and tie although at the time no one called it that. It seems like there may be more to this but I am not sure what is missing.
In the attached sketch a column rotates in plan such that an eccentricity would be created in two directions, is resolving the Pex and Pey force couple along with checking the overlapping area sufficient? With these checks alone you can get pretty acrobatic - it seems like I am missing some other limitation.
