mfstructural
I recently inspected a building for a client where the bases of the concrete columns were spalled and the exposed bars were corroded. I'm planning on providing details to shore up the existing structure above as required, then chip out the loose/debonded concrete to about an inch past the corroded bars. The spec will include mechanical cleaning of bars. Then providing bonding agents and forming to repour high strength concrete patch. I wanted to get opinions on whether its good practice to perform an analysis of the column vs loading. I don't know entirely how many bars there are as all the concrete is not spalled. I'm assuming it's at the 4 corners. I will also be adding a note to remove asphalt and repair concrete below surface of parking area as required. Will probably add a note for engineer to perform one inspection during repairs. Has anyone had experience with similar repairs?
