I have a two part sanyo air conditioning unit for a room which has no windows which has a burnt out compressor. I have a new compressor made by samsung which is slighty smaller but has the same design and could be swapped in quite easily. Both are rated at 208,230V and use R22 however the larger old one has a 54lra rating while the smaller new one is 36lra. The existing one has design specs of 150 psi on the low side and 300psi on the high side while the new one is rated in MPa with 7TP 1.4AP on the low side and 14TP 2.8AP on the high side. Are these absolute and gauge pressures or what? What numbers should I use to compare with the psi ratings on the old one? Are there any other specs I need to compare? Is it even remotely possible to retrofit this one by changing a fuse and/or other componenets in the circuit? Thanks for any insight you can provide.
Sam
Sam
