Compressive stress of bolts? 1
kingnero
BE
I like to use four bolts for setting a heavy workbench level.
For this I would need four pieces of steel, drilled and tapped for the bolts, welded on the bottom of the feet.
Can I use (100% of) the yield stress for this (for the grade of bolt I'm using), or would this not be correct?
Now that I think of it, I've never calculated a bolt for compression. Not even a set screw.
Also, what would an appropriate factor of safety be?
I appreciate your input...
I should have taken my notes before asking this here.
The formula rb1957 has provided, had me remind where I could find the necessary info for this.
Method:
Choose bolt and length in such a way that Lambda (slenderness ratio) gets under 20.
You do so by choosing a certain length, than calculating euler length (pinned - fixed as suggested above), and calculating I from the inner circular rod (that symbolises the bolt minor dia).
Lambda = Euler length / i
with i = sqrt(I/A)
When lambda < 20, you only have to worry about compression force and thread shear.
Compression force should be smaller than 90% of yield strength (using correct units of course).
Engagement length and thread shear as explained in Bickford's handbook.
Done.
Thanks all for your replies.
