Compressive Strenght of PVC trim vs. PT
Smith22
Shed construction an in an area that gets washed out with water flow occasionally. Didn't want to use PT sill and sill gasket but instead use a CPVC trim under the 2x6 wall (with a bottom plate). Best I can tell, PT 2x6 has a compressive strength of 850psi and the CPVC trim is about 1,000 PSI.
Any issue with using this CPVC capillary break in lieu of the sill gasket? I realize it will be more expensive, but I really wanted a waterproof connection to the slab.
Thanks.
