I know that over a pipeline the effective axial force is compressive (negative), and that it builds up to a constant value over the so called 'anchor length'. The 'anchor point' being the point at which the effective axial force in the pipeline equals the friction between the pipeline and the seabed, and where the pipeline no longer expands. This results in the force profile that most pipeline engineers will be familiar with. I was wondering though, does this force profile include the tie-in spools? As I'd of thought the tie in spools will, in some cases if not all, be in tension?
