Question for someone who does a lot of bridge design........
In the IBC 2012, there is still a way for you to have the reinforcement in a cast-in-place, concrete pile terminate at a point (and just have a single bar going down the center) where the pile will always be in compression only and has little moment. (I've typically fought this approach.)
But in the AASHTO code, I really don't see a way to do that. It appears to me that you need the 1-0.5% minimum at just about all cross sections. For those of you familiar with this code (and I don't have the latest): is that how you see it? Do you need to have "the cage" at all cross sections? Is that what you typically see for anything getting traffic loads?
Thanks.
Thanks.
