ConorWalsh
- Jul 18, 2003
- 10
hello all,
I am new to Abaqus and have used Ansys before but am having a bit of trouble adapting to it.
I am currently attempting to model the compression of a hollow rubber seal that is constained between two rigid surfaces and the upper rigid surface begins in contact with seal and then moves down via a dof constraint to comprerss it.
I wanted to model the rubber as a hyperelastic material by using the coefficeints C10,C01 as 80 and 20 respectively, I am not sure what bthe D coefficeint is for. Can you help.
Also I am unsure what element type to use.
Could someone who has encoutered a problem like this before give me some guidlines on the approach to take.
Thanks in advance
Conor
Thanks in advance
Conor
