pradeepburla
I have a small problem where I have to compress the cylinder.
For example if I have a cylinder of diametrer 1 cm ,I want to reduce the diameter of the cylinder to 0.5cm.I donot mind even if the length of cylinder increases.
I cannot constraint any face of the cylinder as I want size reduction even at the edges. Can someone recommend a solution to this problem. I am using abaqus to solve this problem.
Thank You.
Thank You.
