Compressing your files for emailing 1
SBaugh
6,686
I sent this tip to Symmetry Solutions, Inc last week and I thought I would share it, with all of you.
To add to your list of things to do when reducing the file size. I have found Suppressing everything will help bring the file size down. I had a 19.4MB file after I suppressed everything and saved it as a new name it dropped to 454 KB...
I also took a 5MB file and did the same thing and brought it down to 15.1KB.
Hope that helps, Scott Baugh, CSWP :)
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
This is a great thing to make a habit when you are emailing files. Thanks. "Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
I think my other response turned into vaporware.
My counsellor says it is bad to suppress things. . .
It is also painful to recover them feature by feature. Not that I am into recovery or anything, you understand. . .
It was not so much the 'suppress' that helped as the 'save as..' I think. Can you save as various ways and see how muck 'suppress' saves compared to 'save as'?
The biggest savings come from building a feature which subsumes the entire feature set in a simple prism, viewing as wire frame, saving as.. and then mailing them a zip file.
Crashj 'thanks for sharing' Johnson
Why not use WinZip to compress your files? It is much easier than modifying your parts and assemblies. DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
dsi,
Winzip doesn't compress it enough. When you start getting up in the double digits (Ex:15MB) + files. Winzip won't compress it enough to send over email. Although, once I get the features suppressed, I do zip it up. It depends on the file. I do run the Unfrag utility before I do any suppressing or zipping of the features.
sjb@kochllc.com
For very large files, there is a service on the web called WhaleMail (whalemail.com) They allow you to email files (actually more like upload them to a FTP site) and then your customers can go to their sight to retrieve it.
It does cost money, but I forget how much, but it's another option. "Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
