sysengineer
- Feb 16, 2012
- 56
I'm trying to ascertain the dynamics of a compressed air system. A simplified example would be to consider a 5.5 bar supply on 12mm OD nylon tubing to a spool valve with a 6mm OD outlets supplying an actuator 10 meters away.
So for simplicity I have treated the valve as an orifice reducing from 12mm to 6mm (in reality I realise there will be some pressure drop). Based on this assumption I have used Bernoulli's equation for incompressible fluids.
My concerns are:
A) The version of Bernoulli's equation I have used to my knowledge only applies to incompressible fluids or gases travelling at velocities lower than the speed of sound. So do I need to alter my formula?
B) I haven't allowed for friction or pressure drop in the valve or tubing. I would like to know how to calculate pressure drop and friction but I have no idea how. Any ideas?
I have attached a copy of my calculation from Mathcad as a PDF. Please take a look, if I have made any mistakes (likely) please let me know
Dan
My concerns are:
Dan
