KrisB4
- Feb 7, 2006
- 10
Hi all,
I'm designing compressed air piping (in ring form) for my recent plant in Poland.
It will be DN100 (4" equiv.) ring, ca 800m circumference, system capacity is 60m3/min max, 36m3/h at the begining, 8bar pressure.
I'd like to use ball valves for separating parts of the ring (in case of any installation/maintenance work).
My preferred material is stainless steel.
Our sister company in Germany uses black pipes, which are already red from the surface rust (indoor installation, less than 6 months) and butterfly valves, with the same sizes and capacity (both factory use Kaeser screw compressors with refrigerating dryers).
I'd like to use st. steel to avoid any problems in the future from rust and dirt build-up inside the pipes.
My prevoius factory used hot dip galvanized pipes, but they are only protecetd on the inside, and though we used air preparation equipment, we had some problems with air quality.
What's your opinion on using stainless steel (I know it's a bit more expensive but it should pay back in the future) and ball valves (as they do not restrict air flow and have better sealing longevity)?
Best regards,
Kris
Best regards,
Kris
