I have been asked to revise a data set that has a composite TP callout on two holes in-line as:
2X DIA .250-.253
TP DIA .030 /A/B/C
DIA .005 /C
The two holes are drilled normal to the flat datum C surface, so I can see why they want them perpendicular to C, but is it legal to make C primary in the lower frame when it is third in the upper?
As a separate question, is it legit to have a three line composite block? I had someone show me this several years ago who stated it was an "extension" of 14.5. It was used in a situation with multiple holes in line where you can allow say: .030 for the group, .010 perpendicular to datum A, but need all holes in-line by .002 The composite block would have the following for this:
TP DIA .030 A/B/C
DIA .010 A
DIA .002
I guess you could achieve the same with the first and third line shown above in a more typical two line composite and then apply a separate perpendicular DIA .010 /A. True? I like the look of the three line block, seems a bit more elegant than slapping that extra perpendicular FCF below the two line TP.
2X DIA .250-.253
TP DIA .030 /A/B/C
DIA .005 /C
TP DIA .030 A/B/C
DIA .010 A
DIA .002
