Hi everyone,
I am currently working on a steel building with composite floors. My problem is that I don't know how to model the connection between the steel beam and the concrete slab (i.e. modelling the shear studs). Even if I put any constraint to the floor joints, SAP2000 does not consider the beams to be braced on their entire length (the unbraced length factor defined by the software is 1) and therefore I get an error message when checking the design (lateral-tosional buckling).
I know I can change the unbraced length factor manually in the overwrites, but I wanted to know if there was a more "realistic" way of modelling composite floors.
