Following up on tfl's lead--which I think is right--would it be fair to say that:
1. If the wind pressure acts directly on an element/connnection, it must resist CC loads.
2. If the element's resistance to, or distribution of, wind forces is part of the wind force-resisting system, it must resist MWFRS loads.
3. These are not mutually-exclusive categories! A given element may function in both ways, and if so must be analyzed/designed accordingly.
A proposed rough rule of thumb...whadya think?
Back on sda97's original post, I haven't looked at the FAQ's he mentions, but above approach would mean that the connection between wall/beam and roof truss is load path for:
1. Vertical forces originating as out-of-plane wind loads on the roof (wall/beam supporting roof). Greater of MWFRS loads, or CC loads to an area equal to the wall/beam's tributary roof area.
2. Lateral forces originating as out-of-plane wind loads on the wall/beam (roof supporting wall/beam). Again, greater of MWFRS loads, or CC loads to an area equal to the wall/beam's tributary wall area.
3. Lateral forces. acting in-plane of both roof and wall/beam, required to collect or resist roof diaphram shear. MWFRS loads.
Design loads for wall/beam and roof trusses include effects of these load mechanisms, regardless of whether roof truss is flat or gabled.
