common line cutting
simon3015
Industrial
Dec 12, 2016
8
hi all does any one know how to program common line cutting on dr Abe I have no idea
you select the part and you go to grid parts. And choose Grid Parts Method: ABE common cut. and after you are done draging out your grid how you want it press execute and voilá you should have common cut :)
that is the manual way.
you can also do it from the list going into part properties.
Laser engine describes how you can do it manually. If you want to do it in the auto mode... select part properties after choosing the parts you want to give common cut in the make sheet window, tick enable common line cutting, and then choose the different techniques employed for common line cutting, ie part grid, ala logic, ala logic pair by rotation,...each one gives a different result..one limitation i've found is that if you use common line cutting for different parts, auto joint creation suffers. Do give it a try.
