Hi all,
This time I have different issue which is not very clear to me.
Let's say that I have a system with 5 Batteries and 5 Inverters (as it can it be seen on the photo) which are connected to the low voltage grid. For my application I would prefer to have a common DC Bus for all the batteries and the inverters (assumming that the inverters support this "parallel" operation). Let's also assume that the EMU (Energy Management Unit) of the system is capable of balancing the charging and discharging of the batteries.
I read somewhere that this configuration might increase very much the Common Mode Voltage (CMV). How that would happen? Do you see any other problems -electrically related- that might arise from that kind of system?
Thanks again
Thanks again
