Morcego
Industrial
- Apr 11, 2005
- 39
Hi all,
I want to build a simple loadcell amplifier with single supply. I had designed this circuit. Since I dont have that much experience, I will like to ear from you with more design experience.
The power supply will be 5 volt and the gain set to have a full scale of 4,096 volt (the output will feed a ADC with 4,096 volt reference).
One of my questions is regarding a low pass filter to suppress RF and the mains noise (50hz) I was thinking in about 40 hz. The filter is not in the schematic, because I dont know the best way to put it: in the loadcell sense outputs (before the AD623) or at the output (pin6). I had see in the net both designs.
Thanks in advance for any help
M.
M.
