When designing new hydronic systems, we generally have separate heating loops for radiation units (i.e. wall fin, unit heaters, etc.) and reheat coils. I have seen many older buildings where the reheat and radiation are on the same heating loop (i.e. share the same supply and return piping and pumps).
Usually, we see outdoor air temperature reset used for the building radiation units, so the temperature in the piping to the radiation units fluctuates. I could see this being a problem on a combined system, since reheat coils usually operate at a constant water temperature.
By having separate loops you can shut down the reheat at night and just operate the radiation units. Also, with two separate loops there is some redundancy built in, in that if there is a problem with one of the loops, you still have the other one operational. There seems to be several advantages for keeping the reheat coils and radiation units on separate loops.
Are there any advantages to combining the reheat and radiation units off of the same water loop?
Thanks.
Thanks.
