Burunduk
- May 2, 2019
- 2,582
ISO 5458:2018(E) seems to say that the explicit pattern specifications such as the CZ modifier are for cases where some non-redundant degrees of freedom are unconstrained. That is also reinforced by the fact that that there seem to be no examples with datum systems that constrain all DOF in that standard. Also, in ISO 1101:2017 there's an example of a pattern referencing A,B,C (all planar datum features) using no CZ. But what if there are suffecient datums to constrain all DOF, however a locating datum is a feature of size modified to apply at MMVC? Does that require CZ for the tolerance to invoke a pattern behavior and override ISO's default independency and not allow a separate datum shift for each feature?
