august2010
i have to design a combined footing which can take care of 30,000 lbs uplift for a carport. its not difficult to design it in case when i have moment and uplift/downward force acting on the foundation.
but in this case i need to put piles in the foundation. piles will take care of the downward force from the superstructure and foundation will take care of uplift force and moment.
I have attached the drawing for your reference.
i need to know if i should consider the continuous loading from the soil on the foundation bottom when i will design it for compression or should i assume that the foundation is not taking any load even if the pile and concrete acts as one unit.
also should i consider settlement for the foundation and pile. or just the pile?
i can not decide what is going to be the load transfer between pile/concrete foundation in compression.
