asixth
- Feb 27, 2008
- 1,333
Hi
How is combined deflections considered for a metal stud wall system where the top track is fixed to a structural system that allows movement (i.e. a hot rolled channel spanning 8000mm / 27' opposed to a rigid system such as a ceiling diaphram).
For example, the wall manufacturer recommends a H/250 deflection criteria for wall studs. This means that the deflection of the wall studs is limited to 16mm (5/8"). Does this mean I need to limit the deflection of the wall stud in additional to the deflection of the channel to 16mm?
And secondly, what is the maximum limit to wall stud deflections that people normally use? I use H/100 for wood walls studs that normally span 9' (2700mm). Using this criteria the deflection is limited to approximately 1" (27mm).
Is the 1" the total maximum deflection people are willing to accept for wall framing. The governing deflections load case is wind.
