Greetings,
I was shown architectural drawings for a three story building in which the second and third floor exterior columns rest on the end of a cantilevered beam from the first floor, The cantilever beam is 6.5ft long. I did some preliminary calculations and it seems doable (Section size and rebar)for gravity loads, for lateral loads such a discontinuity would be quite problematic; but I believe this problem could be solved by using shear walls in the interior of the building to take all the lateral loads from the columns. I would like any input you could give me on a case like this, I'm not entirely convinced this is such a good idea (well, I think its a terrible idea..)
Thanks.
Thanks.
