I assume you are using the alignment chart method. The AISC commentary says that G may be taken as 10 for a typical "pinned" connection to the footing and 1 for a fixed connection.
Moment frames are always considered sway frames. Only assumed sidesway is inhibited with braced frames or shear walls.
