I'm investigating existing columns (one's a crane column and the other is a building column).
The tips of the flanges of both columns face each other (y-axes are parallel). 6" x 1/2" plates are welded to the outside face of each flange on each side of the column, tying the two columns together. The plates are spaced 36" apart.
Can these plates be considered as bracing against buckling about the x-axis? I'm trying to determine the effective length.
