Column bottom course thickness 2
Dream91
Chemical
Aug 21, 2017
25
Hello
Why the thickness of the bottom course of tall columns has higher thickness than the rest? Is this because of liquid loads and how it is calculated?
Dream91,
With tall columns wind load has a large impact on the required wall thickness. The wind load acts from the top to the bottom on the column. The bending moment is largest at the bottom elevation, where the largest resistance against bending is required, leading to the highest wall thickness.
As you suspected it can be due to static head of liquid. Wind (as noted above), seismic loads, and vertical loads can have more of an impact on lower shell courses.
Possibly due to static head, wind moment, seismic moment, support loading, adjustments of natural frequency, nozzle reinforcing, corrosion issues.
And the weight of upper shell thickness and internals. Like a building.
r6155
