Dec 16, 2010 #1 unkamiko Structural Joined Feb 4, 2006 Messages 12 Location US Can anyone tell me where the ICC code specifies special inspection must be performed for column base plate grout?
Dec 17, 2010 #2 Ron Structural Joined Sep 24, 1999 Messages 16,336 Location US Not specifically required unless covered in the contract documents. If in the documents, must be done. Many treat the same as tendon grouting, which is required to be inspected. Upvote 0 Downvote
Dec 30, 2010 #3 msucog Civil/Environmental Joined Feb 7, 2007 Messages 1,044 Location US i consider it part of the structural steel special inspection. it's quite simple to look at and to check the correct grout is used anyways. plus, you will often find field slotted base plates and ad hoc welded bolts this way... Upvote 0 Downvote
